I have been working on swapping the 5.0 out of my Bayliner with a 5.7. One thing I've been meaning to do is replace the water pump in the outdrive. So I take it apart and this is what I find.
So obviously this thing is sandy and dirty. Is this normal? What should I be looking for on the upper and lower unit which would indicate a significant problem?
When I bought the boat, I checked the lube, checked the prop only spun in the direction of the gear selected. When I brought it home I drained the lube and it looked clean, a few metal shavings on the magnet.
The shaft coming up from the lower unit was caked with crud, the shaft has some minor grooving near the spline, and the pump housing has some minor grooving. Also the seal at the water pump is rotted and the oil passage seal is toast too. Last thing, the front threaded hole is stripped.
