Can a do-e bolt to a upper AQ290 leg
Because I havent heard of a DP-E I wasn't sure if the DP-E are for 6 cylinder diesel
maybe that all depends on the ratio doesn't it??
I guess that is a yes, you are talking about the lower unit.
DP-E is the last in the DP-? series, DP-A,DP-B, etc.
It should fit, I have never done this, and I think something needs shimmed when you install
the lower unit.
DP-E they come in different ratios, yes diesels used the DP-E
