The Honda 20hp seems to run perfect until it gets hot. After it warms up, if I try to give it gas, it will sputter then quit. Then restart it seems to idle fine, but eventually shuts down.. again and again. I tried taking off the carb and doing a thorough clean (twice), but the symptoms were exactly the same. I tried new gas... no difference. Finally, I took off a cover on the back of the engine just above the propellor and revealed small bits of black rubber. I figured these little bits were pieced of the water pump impeller. I removed the propeller and gear case and got to the water pump... turns out the impeller is completely destroyed. So no cool water was being delivered to the engine and it seems to have been shutting itself off. Smart engine. I hope I didn't do too much damage by trying to run it.
My concern is this... what about all the other little bits that are probably somewhere in the engine? Is there a way to back-flush the system to try and remove all of the bits. What caused this impeller to disintegrate? Not what I expect from a high end Honda.
View attachment 10899View attachment 10900
