Mercruiser 454 will turn over but will not start
H1100xx68
I have an 89 baja with a 454, this weekend it started fine and went out on the water and turned it off then would not restart. I have plenty of battery power. Then engine turns over but will not start. Seems like it is getting fuel but no ignition. I need some place to start if anyone has any idea.
Check for spark at plugs or coming out of the coil wire.
If none then need to do the ignition test procedure.
will post it if you need it
make a jumper to go from the +battery to the +side of the coil. see if it runs. remove the jumper to kill the engine and report the results
