Progator135
This is whoopin me..good compression and spark...carbs gone through...clean as a whistle..fuel pump freshly rebuilt (VRO Removed and regular pump put on the pulse hole on side..Front pulse hole has plug)..no change...All fuel lines in good shape and not sucking air. runs great when you advance it to a fast idle..but when brought back to shift gears, will slowly starve and die unless you shoot some gas to it with the key..then itll recover. Ive advanced the idle screw almost all the way no help.
My theory: tell me if im on track...theres a fair amount of slop in the butterfly shaft going thru the carb -both of em...getting more air than in needs from the wallered out shaft holes..but not gettin the gas because theres no suction at the gas tube because its in front of the butterfly....shoot gas from the primer and it goes in behind the butterfly and gets the air/fuel ratio where it needs to be. ( it will die out if you hold it too long. - just a quick tap in on the key is all it takes to keep it alive)
Once you start advancing it accellerates smoothly and runs like a top. Just dying at idle...makes trailering fun.:rolleyes:
How about float level adjustment? They were set barely off level..(looking upside down the non-hinged side was a tad higher) Thats right aint it?
What about bigger Idle jets?
