Got some other issues knocked out now this. I do not think water is circulating into the cylinder jackets. Plenty of water from the pump but all seems to be going through the bypass hose to the thermostat(which I removed thinking it was the issue). Temperature of the block will reach over 200 degrees at which point I shut it down. So plenty of water from the pump but still hot block and head. What should be my first course of action? Might there be an obstruction behind the oil dipstick assembly?Should I remove the head? When I remove the bypass hose there is quite a bit of water pressure so why do the head and block heat up so. Oil is full.Thermostat removed.
