I picked up a 1972 20 HP Electric Start model 204HD yesterday. I, with much difficulty, got the starter off and cleaned up lots of rust from the crank shaft and points, reassembled and got it to fire and run if I squirt a little fuel mix in the carb. Actually sounds pretty good. Anyway, it is not getting any gas to the carb so I removed the fuel pump. It needs a rebuild...no problem. But, is there a secret to getting the carb off? Just from my observation this morning it appears that I will have to remove the starter, flywheel, and all the ignition system to get to the bracket the carb is bolted to on top. Someone tell me the easy way please.
