Hi all,
I am looking for some advice regarding an issue I have with my 1996 EFI Mercury 200 outboard. I currently run a 19" High 5 prop. I have also previously used a 19" and a 21" laser 2.
Growing up, my parents had a 1990 Mercury 200 non EFI on a very similar boat, so I consider myself reasonably familiar with how the motor should perform.
The motor starts and idles well. Acceleration is very good and as I believe it should be. Top end is strong and rev's to approx. 6500rpm (tacho only goes to 6000). The motor will also run at approx. 2000 and 4000 rpm with no issue.
My problem is at approx. 3000rpm. The motor with hold a reasonably constant rpm, however, every 4 to 5 seconds the boat momentarily slows with the sound of the motor temporarily reducing. A car mechanic who happened to be in the boat on the weekend commented that it felt/sounded like 1 of the cylinders was either switching off or receiving incorrect or poor fuel mixture.
This problem has been since I have had the boat, approx. 4 months.
I have just had the boat serviced. Spark plugs were checked and are in new condition, water trap filter, EFI fuel filter and oil all replaced. Motor was compression tested with cylinders all similar and in good condition. He was unable to locate anything that could cause my problem.
The mechanic also tested the coils packs and said they were putting out the correct voltages and operating as they should.
Many thanks,
Andrew
Melbourne
Australia
Many thanks,
Andrew
Melbourne
Australia
