Yep, todays 2 stroke oil is far superior to anything available back then. However, so are the bearings, pistons and cylinders that the oil protects. Personally, I'd stick with the recommended ratio- a bit of smoke beats a smoked piston anyday.True, but the oil back then was so poor you needed to run that rich. OMC tried 100:1 (with disastrous results) and went back to 50:!.
Jeff
50:1 would be the mix
I was given the above listed motor I have changed the impeller and oil in LU. does anyone know the oil/gas mix ratio
