The power trim on my F100 is leaking fluid out the top at the dust seal. I removed the PT unit and unscrewed the end cap (No. 26 in service manual) at the top with a spanner wrench but cant get the tilt rod assembly out of the tilt cylinder. Does anyone know how to remove the tilt rod assembly? Des it require unscrewing the inner cylinder end screw (no 22) or should the whole thing just pill out?
