Progator135
SO I have the lower unit on the workbench waiting for water pump parts. Saw some oil from the shift shaft so I decided to go ahead and tear down and reseal it and check clutch dog condition etc.. My question is this: When I spin the driveshaft by hand I can hear and feel the gear teeth contacting each other. There is a small amount of up and down play in the driveshaft barely less than 1/16 - when I pull up and spin the driveshaft the noise disappears. everything is nice and smooth. Nothing is grinding and theres no metal shavings in the oil. Adding shims would only send the shaft farther into the case so that wouldnt fix it. I know the tolerances here are critical so Im not going to be doing anything until I get some feedback. What do yall think?
