Hello everyone. I have a mercury 225 carb that is having issues. Motor has low hours (140hrs). Boat sat for some time before I purchased it. I have ran the boat a few times and noticed that its idling rough but not terrible. Got home today and put the timing light on each plug wire and discovered the #2 coil was not firing properly. The same occurred with #5 but I couldn't get it to act up again after I went back to it. Thru out the day I noticed that it wasn't smooth at idle. With the timing light still connected I brought the rpms up to 1300 and everything smooth out. Light fires continuously but then when I bring the idle down it starts missing again. I switched the coils and the problem didn't travel. Put the timing light on the primary leads to the coil and its erratic as well. Shut the motor down for a minute and started it up again after 2 mins and couldn't get it to act up again. Double checked connection with timing light before and after. Where should I start looking for the culprit? This motor has the electronic ignition timing so that cannot be adjusted. Checked continuity for ground on each primary lead, all was good. Motor runs strong. Pushes my 25'1" Proline walk around to 46mph at 5300rpms. Could go higher but didn't feel it was necessary. Thanks for reading and happy boating.
