Scottatwater
New to forum, pros-cons on replacing drain plug with for ex. Fumoto F101 type valve.(short or long) nipple?
I don't much care for the dipstick extraction method. The dipstick is of small ID, and will be slow unless the oil is warm.
An actual drain hose installed directly into the oil pan works much better!
No need for the valve if done correctly.
The remote drain hose will have either a plug or cap at the end.
Your oil extractor will connect to the remote hose via the same but opposite plug or cap threads.
