Snakeriversailor77
Im working on a 2002 Mercury 75 HP two stroke 3 cyl carb motor. The engine began smoking at running speeds and according to the owner it felt like it was "missing a gear". It appears that it is over oiling somehow as the exhaust is spitting oil and fuel. Initially it was thought that new spark plugs, filters and a carb cleaning was the answer but that didn't change anything and if anything, it caused it to smoke more. The engine idles rough and misfires which belches blue smoke when it does. At idle, this misfire can kill the motor. It was suggested the problem was a leaky fuel pump diaphragm which was causing excess fuel and oil to get inside the motor through the pulse circuit, no pin holes or tears were found but new diaphragm and check valves were installed. No change. The recirculation/evacuation lines are clear. The check valve between the oil pump and the fuel pump was replaced. No change. The engine still smoked after disconnecting the oil line and running a shop tank mixed 50:1 and new good quality non ethanol fuel too. The timing is right on, and spark is good at all cylinders. A faulty meter showed the CDM's to be bad but new CDM's didn't solve the problem either. Compression is good at @125 per cylinder. Carbs were cleaned a second time with no change either. The only previous issue with this motor was a leaky oil cap. The discharge water is only a few degrees warmer than the river water after prolonged fast idle. Replaced the thermostat and poppet valve thinking that the cold condition was causing an over rich condition. Didn't solve anything and still smokes badly enough the Mosquito Board is thinking of paying me to run it! Help!
