So I am new to outboards but am very experienced in heavy equipment repair, so I figure much of it will be the same but on a smaller scale. So it really over heated today and stalled out on us, engine had a new impeller fitted, it had the oil level alarm going off prior to the failure but still has oil, the port head lower 2 cylinders were extremely hot, melted the coils and a couple of wires that touched that head, prior to this it ran extremely well.
I go it home and figured to pull the port head - cylinders look good, the lower two head chambers were extremely clean - water in the combustion chambers maybe???
the head bolts were loose when i removed them, it had a new port head gasket prior to purchasing it, do the heads need to be retensioned???
Could that have caused the failure??
there is a sensor at the top of the port head light brown single wire - was not connected, similar two wire one on starboard head - are they temp sensors???
there is also a magnet failure in the flywheel, I am yet to pull that off to see if there is any stator damage and replace the damaged parts,
Do the heads suffer with cracking or going soft?
Can I just replace the gaskets after cleaning the surfaces?
Will the thermostat require replacing or can they be tested?
What tension are the head bolts?
Any further advice would be appreciated.
Lastly does Yamaha share engine components with this engine or copy the engine design as I have seen a 200hp yamaha for sale, 90 degree v6 with what looks like identical heads and air intake.
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/ia4AAOSw-W5Uw1hb/$_57.JPG
