FishPirate
Hello to all,
I posted my dilema on THT and some of the guys suggested I run this by you guys. It's kinda long winded but it explains where I'm at so bear with me. This is a copy from THT...
I sold my Striper awhile back. After some seaching I purchased a 2002 246DC World Cat. It has a pair of 2004 150 Hondas with 260+ hrs. During the pre-puchase test ride I noticed the starboard engine didn't pee as good as the port engine. Then when pushing revs up over 5000 for a bit the overheat alarm would sound. I figured it was probably a tired impeller and after taking it to a Honda dealer and having him check things he gave me a thumbs up. (for what thats worth, his shop was near the selling broker and I lived 1200 miles away). Well, when I got the boat home I did a lot of work on it. I replaced both water pump impellers even though they didn't have much wear but had a lot of "set" in the fingers just from age. I put all 4 thermostats through a hot water opening test and the one for the block on the starboard (overheating) engine failed to open even when the water was brought to boiling. I replaced that one and the engine now does not sound an alarm when run at full throttle. The thing that baffles me is the pee stream is still almost as weak as it was when I surveyed it. I would guess that it is flowing about 60 percent of the other engine. When I flush using the garden hose fittings I use a "Y" so I can do both engines at once. It's the same deal, the port engine pees real good pressure and the starboard just dribbles, barely makeing a stream. I removed and cleaned the flush valves and the bypass valves located under the head. No improvement. The one main clue I have is the port engine that pees good has a lot of water loss out of the pick-up screen while on the flush hose,while the one that won't pee right has very little water coming out there.I am hoping someone here has experienced this and found their problem or maybe someone understands the cooling system well enough to throw me some possiblities. Thanks for any help.
So there it is, one thing I might mention is when I replaced the impellers I did not replace the tube seal at the top of the pump housing. I wish now I would have.
Anyway, it's good to have found a group with the same equipment as mine and hopefully we can drink a toast to my solution.
