Results 1 to 3 of 3
  1. #1
    Default What prop size for a 1972 65hp Evinrude should I have
    I have a Sea Nymph V13 with a Evinrude 1972 65hp engine. The prop currently on the boat is an 18 1/4 x 17. This was put on by the previous owner after he broke the original prop and it was a second hand one given by a local to keep him going.
    From what I have seen on trawling the net I cannot find anyone suggesting a prop of that size for a similar size boat/motor.
    Is there a calculation to give you the right size, pitch etc?. I understand that it can depend to a degree on what you are doing with the boat etc, I am only fishing, occasional slow pull round with a sea biscuit for the kids, general use, not going too far each trip, bit of lake use and sea use but obviously would still like to get reasonable power etc
    Any ideas at all on what size prop I should be looking at???
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,156
    Default Re: What prop size for a 1972 65hp Evinrude should I have
    Is it 13 1/4 diameter ????????????
  3. #3
    Quote Originally Posted by kimcrwbr1 View Post
    Make sure the hull is clean, engine running close to 100% as possible, proper trim angle. Then check WOT rpms. Compare that to proper WOT rpm for your engine. If the Rpms are too high increase pitch angle if too low decrease pitch angle. General rule is 200 rpm per inch of pitch. Every boat is different you need to adjust pitch for your paticular setup.
    Thanks for that Kimcrwbr1, will check that out.
    Your right raceone, it is 13 1/4, I could have sworn it said 18 but it was hard to read (should have had my glasses on :-) ). That sounds a little more like what is stated on other sites.
    Thanks again
Similar Threads
  1. what size prop do I need 1972 50 hp Johnson
    By rivins in forum Johnson Evinrude Outboard Forum
    Last Post: 02-01-2013, 01:04 PM
  2. 78 65hp Chrysler prop size
    By weglin77 in forum Chrysler Force Outboard Forum
    Last Post: 07-04-2012, 06:34 PM
  3. Engine's RPM range prop size 1972 70hp
    By mac_55 in forum Chrysler Force Outboard Forum
    Last Post: 07-03-2010, 11:22 AM
  4. 1972 Evinrude 65hp wonbt shut off HELP
    By sgruebs870 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-23-2008, 10:38 PM
  5. Evinrude 65HP 1972 Oil mix ratio
    By agforman in forum Johnson Evinrude Outboard Archive
    Last Post: 07-28-2006, 04:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
