beaverbeliever
I have a 2002 kicker that runs very well albeit a little cold blooded until it warms up. Once I quit using ethanol fuel I no longer had carb plugging problmes. The only complaint I have had with this motor is an annoying rattle from the throttle handle while I'm trolling at low speeds. I've tried all sorts of measures but nothing really has worked to stop it other than holding your hand tight around the throttle grip. I found somewhere that this might have been a TSB or replacement issue but I never found the published bulletin to verify and I didn't acquire this motor until it was 8 years old. I don't use the throttle handle much as I have a pro-trollmaster that connects directly to the throttle at the carb. The friction knob doesn't tighten very tight before it will click and then loosen up before tightening again but not completely tight. I went online this week and found that the original throttle knob and friction plate have been updated with new part numbers. I had them shipped and installed it last night. The friction knob seems to be able to tighten down much tighter than the original unit. I'm hoping this may have solved the rattle problem. I'm posting to see if others have had this problem and if it solved my problem I wanted to let others know what I may have found.
