Flat Head Screw with long unthreaded shaft on bottom of Force 125
777funk
What is this screw? It's a flat head with a long non threaded shaft and ball shape on the end. It's on the bottom near the prop but bottom/side of that area.
Oh no! its the pivot pin. I took mine out assuming it was the drain. The motor still shifts in and out of gear (able to spin prop by hand only in nuetral) so it must have somehow stayed put. It's cold here today so I assume thick oil.
Am I right that I'm ok based on gear shifting I mentioned above?
If you can shift it in and out of ear as you spin the prop(motor off) with your foot.
It should be ok.
And yes you got real lucky.
I charge 200$ to fix that.
