I just picked up a vintage Force 125 outboard that hasn't been run in 6-7 years. Is there anything I should do before I crank it?
I know in 4 strokes (car engines), it's a good idea to lube the cylinders before cranking. In a 2 stroke is there anything that should be done before I crank to protect the moving parts that may be dry from time?
I'd guess the carbs are filthy as well so maybe clean those. Anything else I should address?
