bassraider
My 1984 2HP Seahorse (J2RCRS) is configured differently than the manual describes. There is no cam roller on the cam follower. Instead my engine has a piece of hard rubber attached to the cam follower that makes contact with the armature plate when the throttle control is moved. It's therefore impossible to adjust it between the 2 marks on the armature plate as described in the manual.
I would like to "upgrade" and install a new cam follower that uses the cam roller. It seems to be a better system. I have identified the following parts as needed for this project. Can anyone tell me if there are other parts that I should order for this upgrade? Thanks.
0330286 - Link
0330190 - Washer
0312831 - Screw (shoulder)
0323327 - Cam Follower
0323326 - Roller - Cam Follower
0330346 - Screw (adjustment)
0330286 - Link
0330190 - Washer
