flabob1
I have twin 2005 Yamaha z150txrc HPDI engines. I had the oil tank low level alarm go off on the right engine. Checking the engine tank I found it below or at the low level line.Filled it manual and it was OK until it got down to the same level. Checked and found the pump on the main tank works oK when the switch on the engine is worked.So why working the switch it pumps oil to the engine tank but when the engine running it does not? Any help on this problem would sure be appreciated. Thanks, Bob
