Yes - search the site for issues with the 225.
I have over 1600 hours on my 225 and it has been a great engine, but they do need to be maintained rigorously IAW the maintenance schedule in the owners manual.
There are two known weak points on the 225.
One: On the older engines, and I'm not sure when this was fixed, the middle drive shaft bearing (bushing) in the middle section has been known to fail and literally eat through the lower casing. The failure is apparently caused by too little raw water going over the bushing to keep it cool and lubricated. I've never had this problem on my 2007 model year, but some folks with older motors have reported it.
Two: Prior to 2007 there was a problem with the old-style exhaust tubes that under certain conditions would allow water to get way up into the exhaust tube and damage the expensive HO2 sensor. In the worst case, that water could get into the #6 cylinder and literally seize up the engine and destroy it. This issue is covered by Honda Service Bulletin #56. If you send me an e-mail at
[email protected], I'll send you a copy of the service bulletin so you can check the serial numbers of any perspective engine you may want to purchase against those listed in the service bulletin. If the SN of the engine does fall within the effected range, then you need to check to see if SB #56 was performed on the engine, or have it performed before purchasing. Honda sells a kit for doing the complete change out.
If you do purchase a 225, and you are a bit handy with tools, then purchase the official Helm Shop Manual for that engine. You can get it on eBay or Amazon. It is about $116, but worth every penny just for the detailed maintenance procedures and diagnostic procedures.
There are several trained Honda Tech's on this site and they have all been extremely helpful to us amateurs.
