Hi all
I have an electric shift 1972 65hp evinrude, model 65273S, the gear seems to be stuck in forward, I have learnt from having read some of the forums that this is the default position if something goes wrong with the unit, but has anyone got any advice on how to track down where the problem may be?
So far I have tested the voltage at the gear shift cable connections. when the shift is in neutral there is power to only one wire, when I shift it to reverse there is power to both and when I shift it to forward there is no power to either .....a previous thread on here has advised that this is the way it should be so all seems to be ok there, so I assume the problem may lie in the solenoid.
How do I test the solenoid? or is there something else I am missing or some other test that can be done that might isolate where the problem lies?
The cable has been broken in the past in the exhaust housing and has been repaired, the repair looks good and does not appear to be loose or faulty, the connections are well sealed so not sure if the problem lies in this area or not.
Any advice would be greatly received
