how do i flush a 86 125 force
iseablu
hi all,is it ok ta run engine when i use ear mufs? i ran it for about 6 or 8 secons and shut it off when i didn't see any water.what is the whole
procedure? thanks,roger a.
Yes you can run the motor when hooked to the muffs.
Just make sure the pressure is enough.
The water might take a bit to circulate up into the head and then out the snout.
I sometimes duct tape the muffs in place if I think they don't fit right.
The tape won't work if you use it when the lower is wet.
Just make sure it's dry.
No special procedures just hook up, turn on full blast and start.
Then if you don't see water after a bit you'll probably need a new impeller.
