Hi guys. Thank you all so much for answering my last question so quickly. I have now ordered the water pump kit and waiting for it to arrive. I have made a silly mistake and did not take the motor apart before ordering the parts. I have now done so and found a damaged part in the gearcase.
The housing has a small pin attached to it. As you can see in the attached image, the casing of the housing has a very small crack and the pin is loose and comes off easily. The part number is 0397186.
Is this a significant damage? Should I replace the whole part, or should I just remove the pin and put it together? Or any other suggestions to fix this?
Thanks for your help. Joe
