Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2009
    Location
    Wareham, MA, USA
    Posts
    28
    Default Motor tilted up or down?
    I have twin 2001 Evinrude 70 hp and want opinions as to whether you tow just resting the motor tilted down to make contact with the hydraulic rams or do you tilt up so the lock is engaged about horizontal?
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,649
    Default Re: Motor tilted up or down?
    If you have the clearance it's better to trailer down - there is less stress on the transom. If you must trailer with engines raised, it's best to use an outboard brace to prevent the motors from bouncing and turning.
    See:http://www.easternmarine.com/Outboar...upports-Locks/
    CHawk 25 DLX
  3. #3
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    http://www.m-ywedge.com/
    i have been using this for about 4 years....i went to it because i could not find a regular transom saver that would fit good between the fins etc on a new merc..broke two of them and was afraid i was going to eventually damage the motor..am happy with it...i think you have to have power trim to use it though to lock it in place..the motor will still pivot though but i found out if u just go ahead and turn it to one extreme then it will be solid as a rock on the hwy....
  4. #4
    Join Date
    Oct 2009
    Location
    Wareham, MA, USA
    Posts
    28
    Thanks for the link. Wound up using a 2x4 for this trip. I think a m-ywedge is in my future...
Similar Threads
  1. BAYS-3400122 BF40A.... tilted motor slowly goes down
    By shero144 in forum Honda Outboard Forum
    Last Post: 09-30-2013, 11:41 AM
  2. Priming engine with Outboard tilted.
    By Centurian in forum Mercury Mariner Outboard Forum
    Last Post: 12-24-2011, 11:53 AM
  3. carb empties when motor tilted 1981 90 hp
    By weasel in forum Johnson Evinrude Outboard Forum
    Last Post: 05-04-2010, 04:59 PM
  4. Tilted engine will leak oil from top fill cap
    By madmaxx in forum Mercury Mariner Outboard Archive
    Last Post: 12-14-2008, 07:21 PM
  5. Does the motor have to be upright to flush tilted
    By bryansdavis in forum Mercury Mariner Outboard Archive
    Last Post: 05-10-2008, 10:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
