GoodChance
2008 BF50 - I cleaned and replaced all gaskets on the three carburetors two months ago. Since then, I've run the motor several times and motor runs smooth at idle and strong at higher rpms. No issues a all until last week.
Motor still runs strong but after 4-5 minutes of running at 3500rpm,she runs out of gas. If I manually pump the fuel bulb, she runs fine again. But I need to force fuel into the primary filter. Please note, that I have a large-canister Racor primary filter (30 micron) in front of the motor as well as the secondary filter inside the motor. Both filters are new and I have run both for several years without any problems. Also, at a fast idle (1500-1800rpm), she willrun out of fuel in 5-8 minutes.
The fuel pump is actively “sucking” and developing pressure. That doesn’t seem to be the problem.
Maybe the anti-siphon valve in the bulb is bad? I suppose that I will install a new bulb tonight and see what impact this might have.
What concerns me is the vacuum lines. When I have thecarbs off, I failed to reinstall the black vacuum lines for the top 2carbs. But the motor seemed to run justfine without them. And I’m not certainwhat these vacuum lines do. See attachedpictures. Might my problem be related tothese lines? And if so, why have I beenable to run the motor for 5 hours at high rpm since the carb rebuild with noproblem until now?
