I had posted this on another's thread...A member here has suggested I start a new thread on this subject. He said to ask for Honda dudes help....From reading posts it looks like the engine light coming on at idle could be a common fault with the Honda 90.
I am a partner in a boat in Mexico we have a 2011 Honda 90 with about 400 hours on the engine.
We fish off the west coast of Mexico in a place called Barra de Navidad
This is my story about the alarm.
We were 10 miles from our Marina when I noticed water pouring out of the engine case.I pulled the cover off the motor and the bottom of the case was flooded with warm water the pee hole had water coming out of it ,but thinking back on i with not the normal pressure... I checked the oil in the engine it looked clean and the engine was running normal but water was coming from somewhere so we trolled back to the marina. I called the Honda mechanic and he had to take the cover off the leg and we found the tube that runs the P water had come off .OK here is where the plot thickens... Next time out fishing when we were out 15 miles right before we caught a big Marlin by the way. We had a check engine light alarm with a slow loud beep when we put the motor to idle.I turned the engine off and looked around the motor then turned it back on..it started with no alarm. Any way after that every time we put the boat to an idle or neutral the alarm went off. Yesterday we had the Mexican Honda mechanic come to check the boat..I asked before he came if he had a scanner to read the code that was giving us the alarm he said yes..(all conversations are in Spanish so a little can be lost in translation) anyway he showed up with out the scanner and had me turn on the engine and proceeded to check the oil in the motor as it was running. He showed me the dip stick and said the oil level was low and the oil viscosity was too thick and asked me if I was using Honda 10 30 oil? Unfortunately I don't do the maintenance on the boat my other partner does it and I could not answer his questions. It's funny in all my life I never saw anyone checking oil in an engine while it was running! He explained that an outboard motor was different from a car engine..while the engine was at idle we had about a 1/4 inch of oil on the dip stick .. he then had me rev the engine and he then checked the oil level and the dip stick was clean no oil! After that display we had him change the oil and filter with 5 quarts of Honda 10/30 ...now when he checked the oil level with the engine revved up it showed about 1/2 on the dip stick...He thought that maybe the thick oil and low oil level might be our alarm problem. After the oil change we went fishing... again out over 15 miles trolled around for over an hour idled the boat several times and no alarms ...We trolled back and about 5 miles from the marina we had another marlin strike which we lost after a brief fight...but while we were at Idle the damned alarm went on!! We will get the Honda guy to check the code but I'm willing to bet that it will be the H02 sensor...which I suspected was the problem after doing some research on it..I suspected that because of the water we had enter the engine compartment when the pee tube came off.
I would sure appreciate any constructive comments on this problem and on checking the oil level while the engine is running.
After talking to another member here who had mentioned in a separate post that you can check for the engine trouble codes by using the kill switch button...I had noticed the mechanic doing the same procedure and I now know he the mechanic probably knows what code it is.
If Honda dude would be so kind could you comment on the check engine alarm at idle and also I would appreciate his comments on checking the engine oil level while the motor is running.
Thanks in advance ...oldgringo
