I dont think its an accessory Joe - If you look at the Parts diagrams - Everything points to a 12A system and the "crankcase and cylinder" diagram shows the regulator and refers to my motor "for 135589 only"
Thats my next step.... shooting for Friday. May get some extra wire and some terminal ends and rig an extension on my voltmeter. The dash guage pretty well matches what my digital charger is reading before I unhook it. Usually 14V or more. But probably better to read it right off the battery with teh digital.Check the voltage at WOT without the voltage regulator at the battery. .
...i dont mean to sound like a hardass but we are jumping around too much....we need to make a decision on the stator area and go one way or the other on the problem..
I have a TACH working good, strong signal on ignition / fire up but no charge. Engine will run strong all day & TAC
I have a 2001 Johnson 200 HP and she runs GREAT. nothing wrong with the motor but the electrical has been a complete night mare for me..
I Have tested with multiple meters and the engine isn't putting nothing out.. Not even at 4400 RPMS , i have no increase in voltage anywhere on the boat.She does not charge at all. When i run my tilt / trim, boat trim tabs , and when lowrance is on it dims out. I need this motor to charge :/ I'm at the point of needing to find a expert on the east coast and traveling / taking the boat to them.
I have a new CDI power pack, Stator, Voltage Regulator, Timer Base, Ignition, Battery, Perko switch, nothing. I've printed the entire CDI manual and everything is hooked up correctly. I am very mechanically inclined and patient. I've replaced about everything, I've tested ohm test on the entire ignition harness, (I have done no DVA tests, engine runs GREAT!!!) I have over 15 hours trying to troubleshoot this and i am at a total loss. I've ohm tested / checked the main (-) and main (+) off the engine going to batterys i can't find any issues with corrosion nothing, no wing nuts. I have no charge at the main starting solenoid or any wire on the boat. I really can't figure out what the issue may be and ive replaced just about every main component related to the charging system.
