Results 1 to 10 of 10
  1. #1
    Default Brute 767 foot pedal tension
    I have a brute 67 model 767 12/24v that came on a boat I recently bought. I think it's a 98 model. The foot pedal is very sensitive and easy to press. So easy that when I hit the momentary switch the lower unit spins around due the the motor torque and I constantly over control when trying to steer. I cannot find any place where pedal/cable tension can be adjusted. Is there a way to adjust the tension so the direction can be controlled without fighting the pedal?
  2. #2
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default Re: Brute 767 foot pedal tension
    i dont think the problem is the foot pedal...i think the problem if as stated is in the gearing ...a foot controlled trolling motor should hold the direction it is in when power is applied..also make sure the polarity on that motor is correct...(hooked up correctly)..
    you can take a foot controlled trolling motor and lower it while the boat is on the trailer....grab the foot and turn it...watch the pedal...you will be able to turn it but it wont be easy..Unplug it while doing this....inadvertently touching a switch while hands are near the blade can be disconcerting)
  3. #3
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    767
    Here's the exploded view and parts list if it helps.....................
    http://www.boats.net/parts/search/Me...%29/parts.html
  4. #4
    Thanks for the info. I have tried turning the lower unit as described and it is pretty easy. The pedal moves as expected. Guess I need to take the top off the upper unit and see what's going on.
  5. #5
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    after thinking about it i cant remember turning the hi speed switch or any switch without my foot on the pedal to control direction...yours may be operating normally and you will just have to get used to the way it operates and the limitations..
  6. #6
    I hope that's not "just the way it is". Even with my foot on the pedal I can't control the direction when it starts. It seems like there is a "peak" in the pedal travel and when you get to the "peak" the the lower unit will swing wildly past the "peak". Then it's left and right until I get it to go where I want. Only a small change in direction causes over steer unless I really put pressure on the pedal and concentrate.
  7. #7
    Just heard from Motor Guide. They said there was no tension adjustment on the 767 and directed me to www.trollperfect.com for an add on tension device. Looks like it might work OK. For $24.95 plus shipping it's worth a shot.
  8. #8
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    good to know...please get back to us on results...
  9. #9
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    looked at that site...live and learn eh?
  10. #10
    Troll Perfect is on the way. Will post results in the future.
Similar Threads
  1. How do I disassemble a foot pedal assembly so I can replace a broken toggle switch?
    By tiny_dr_tim in forum MotorGuide Trolling Motors Forum
    Last Post: 02-11-2015, 08:05 PM
  2. Brute 765 problem - No variable speed control
    By eagleone622 in forum MotorGuide Trolling Motors Forum
    Last Post: 07-08-2013, 09:49 PM
  3. Motor Guide Brute 750 Trolling Motor Parts
    By Donewright in forum MotorGuide Trolling Motors Forum
    Last Post: 04-09-2012, 07:16 AM
  4. terrova wont repond, auto or foot pedal
    By rickhise in forum Minn Kota Trolling Motors Forum
    Last Post: 04-05-2012, 12:38 PM
  5. Big foot 50 hp 4 stroke for a 17 foot aluminium boat
    By mario in forum Archive 2003-2009
    Last Post: 07-07-2003, 11:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
