I have a 1997 Honda BF90 that has been leaking water into the flywheel area. I can pop out the starter and see that it is seeping from a little plate just under the edge of the flywheel.
I had a shop repair it, but it is still leaking. I took it back and the shop found a service bulletin supposedly that calls for a redesigned extension case, p/n 40201-ZW1-020ZA, which they did not know about before.
This part is about $600 so the shop is not willing to cover that.
Can anyone validate this is a problem or know of an easier fix to the issue? Supposedly this new case has a relief passage that relieves the water pressure from behind the leaky plate.
Thank You for any help and assistance!
Rob
Rob
