fish_fear_me
Hello all! Okay, here's the deal as it relates to the lower shift cable on my 87' Cobra sterndrive. Situation: Cable itself is fine, but the shift cable shield has separated an inch or so back from where the cable enters and is attached to the shift cable guide (back side of the pivot housing). Question: Albeit a tight fit, could water seep thru the casing into the engine compartment? Unfortunately, problem was only caught after new gimbal bearing, U-joint bellows and exhaust boot were installed and unit re-assembled. OUCH! Wondering now, if I'll be needing to turn the heat up in the barn, tear her down and replace the thing. Definitely wasn't looking for another winter project!
