FatlukeNofx
Hello, I have a 1995 Larson Cabrio 310. It has 2 mercruiser 5.7L alpha 1 gen 2 outdrives, however the starboard side outdrive is a little out of alignment, what I mean is, even though the port outdrive is pointed straight back, the starboard will be slightly off, making steering a little diffcult. How difficult is this to fix, and how do I do it.... The boat is currently pulled out of water for the winter.
Also, on the port out drive a small hose disconnected at the end of the season and I didn't notice until the very last week, then when I started the motor, oil started to slowly plume into the water, I checked the outdrive oil reservoir, and sure enough it was low. So I added more to top up and after a few more days it was definitely lower. When the boat was pulled I looked at the outdrive and crazy enough a small clear hose full of green outdrive oil with a strange twist fitting was disconnected... I poked around for a bit and saw where it was to go, then hooked it back up. But a couple weeks later I came back to visit the boat, and the bottom of the outdrive, basically leaving the water intake port, was wet and shiny with oil... So I wonder, was this just left over from the disconnected hose, or is there a deeper problem. I will attach pictures. Thanks for the help guys, this is just so frustrating.
