I have a Honda BF 50hp efi (fuel injected). Many times when I try to start it, it takes 5 to 6 tries to get it to fire up. It sounds like it is going to start but once I release the key it dies. I can advance the throttle in neural and turn the key. That often is a big help, but then it reaves up to 1,500 rpms as it starts. I can push the key down (choke?) when I turn it, but that doesn't seem to make any difference. I do not hear any sound from the engine when I push the key in (should I hear the choke solenoid?).
It idles at about 850 to 950. I have tried to adjust the throttle linkage to increase the idle rpms in hopes that would give it more gas at ignition. I am maxed out on that linkage adjustment and it didn't help much. This is a relatively new problem that is getting worse and worse. It now happens about 80% of the time I start the engine. It runs beautifully once started. This happens in hot and cold weather.
Of course the problem is intermittent and seems to happen more deep in the LA marsh than in my garage.
I have also tried the following:
New water/fuel separator filter
New plugs
New high pressure fuel filter
New in line fuel filter
Fresh gas
Have run several cans of different injector cleaner
High and medium octane non ethanol gas
My other thoughts are:
Some efi sensor is not sending the correct feedback to the computer or the computer is malfunctioning at start up. Any thoughts what sensor I should replace if any? Do you think a computer diagnosis might help (I don't have one). Should I pull and clean the injectors? If so who does the forum recommend.
Or should I just haul it to the shop!?
This forum has been a big help in the past and here I am again. I appreciate any feedback.
New plugs
Fresh gas
