TheSouthMerc
Hi everybody from the deep south Argentina,
We own (with my dad) a '90's Merc 50 HP 3-Cyl 2 stroke ELPTO Oil injected
My dad has some background servicing engines, carbs and so. And I'm the electric/electronic geek of the family, so we complement each other
Our engine works like a charm (around 550 hours usage), we bought it used on a Campanili explorer 440 (around 15 ft) locally produced hull, that is very light, so we are getting great performance from the engine without even forcing it, our cruise revs are around 3000-3500 RPM for 40-45 km/h around 25-28 mph, and we get a little less than 2 gallons hour of fuel consumption, so we are delighted of the engine.
Anyway, we have an issue:
- when the engine is tilted and stopped for a while (let's say 2-3 weeks), a small quantity of oil drips from the cylinders trough the carbs and deposits on the engine lower cowling. We hear mixed opinions around here about this issue, but we really don't trust very much on any of the "mechanics" or service centers around here (will explain later on why)
One of the opinions is that oil dripping is actually normal when the engine remains without use and a small leak develops because of gravity trough the oil pump or the remains of fuel-oil mixture on the carbs and ends up on the lower carb or cylinder. The only apparent effect is seen when we re-start the engine and we are observing too much "blue-smoke" due to the enriched mixture containing oil in excess. After a short while the engine is running smoothly again, without abnormal smoke.
A "mechanic" told us that a good way to avoid this is to get rid of the oil injection system and mix the oil directly in the tank (like the old days of the 50:1). We don't like this option:
a- because this system seems to work fine on the engine and is very comfortable and simple to operate, apart of the oil drip when not used, and
b- because we think the manufacturer engineers are less stupid than our "mechanics" friends, and also, the engine has been running for almost 20 years like this without problems, so... why change that?
We were thinking also on a possibility, regarding the oil check valve maybe not closing correctly before the T were oil mixes with the gas, just before the fuel pump:
Item 24 on the fuel system diagram here:
http://www.marineengine.com/parts/mercury_marine_parts/sn/0G291556/1050411SD/1680_120
Maybe oil slowly flows to the carbs because of gravity effect (the oil tank level is higher than the lower carb) due to a failure to close from the check valve. The gasoline evaporates from the system and at the end only the oil remains. Do you guys think we are on the right track over here? or maybe you have already a diagnosis for this issue.
Our distrust on the service centers came from the fact that upon buying the set (hull+engine), we service it on a local official dealer. After a short while, the engine started to cough a low RPM and when on gear sometimes stalled. Dismounted the carbs and found ancient history gum on them. After that, we decided to take the matter in our hands and service the engine ourselves, at least on the normal issues. So, we are replacing filters, transmission oil, impeller change and cleaning the carbs ourselves, and we are sure about the job done, and so far the results have been so much better than "the mechanics" around here.
Currently I'm trying to get a Mercury or a Seloc service manual, but with import restrictions around here, specially on online shopping and delivery, lately is getting hard to buy... so all we have for the moment is what we can find around the internet. This forum has been already of a great help so far, and all your opinions or heads up into any reading material would be of a great help to our little Merc...
Thanks in advance from the south fishing Merc...
good boating and good fishing over there
