1..... It is belt driven. The alternator only has one red wire coming from it. At least that's all I could see last night in the dark.
2.... Does it need a ground? Any help troubleshooting this?
1..... As the guys have said, if the alternator is now belt driven, the kit has been installed. Most of these kits use the Delco 10si as the replacement.
2.... The alternator chasis and mounting will provide the Negative path to the engine block, but it's always best to install what's called a "chasis to engine block" Negative cable. I'd size this identically to the charge lead.
1.... Just checked it. Ran her up to 2000rpm and it was 12.0 at the batts.
2.... is there a voltage reg somewhere also? Any other ideas other than pulling it and having it tested?
3.... Btw how long do you think it can be run before it dies if the batts are fully charged? (Electronic ignition) I was able to get through most of the day yesterday But only ran 20 miles round trip. The rest of the time I was on anchor with one battery off.
1.... The single wire 10 si requires a bump in rpm to become excited. Once excited, it will remain excited until shut down.
If at 2k rpm it did not self excite, then something is wrong with it or the charge lead.
2.... The single wire Delco 10si will have an internal regulator.
3.... As for battery run time without charging...... this will depend on the battery's health and your loads in Amp Hours.
Keep in mind that a wet cell battery left in a SOD for any length of time will begin to shorten it's life.
I'd get it charged back up ASAP.
1... Its a 105amp and I think the one I had was a lot less. Any concerns using the ebay alternator?
2.... The one I have is a one wire that runs to the starter.
1... Most standard and common 100 amp alternators will cut back on the charge rate rather quickly. So it's sort of a misnomer to think that these will maintain anywhere near 100 amps for any duration.
In order to get into a 100+ amp Marine alternator, we've got to spend some big money.
2... Unless this is capable of 100 amps, or even near 100 amp..... keep the original circuit. This should run to the red button circuit breaker and then down to the starter motor's solenoid terminal where the MBSS common cable connects.
yeah, your output wire may not be sized to handle 105Amps. Check the gauge of the output wire and follow it to a breaker and see what the breaker is rated for - get an alt with that number.
Agreed!
If the alternator is anywhere near capable of producing a 100 amp output, this should be upsized as well as the Negative cable.
........... Can I run a lead directy the battery instead of to the starter (and breaker)?
I would not..... I'd keep the path the same, and upsize wire gauge if need be.
When we start circumventing the OEM, we open ourselves up to possible problems.
