s2sailorlis
This is a new to me motor that came packaged with a sailboat I recently purchased. First time owning a two-stroke - as I had a diesel inboard before this, and a 4 stroke on a smaller boat in the past...
On this motor toward the bottom of the Drive Shaft Housing there is a rubber grommet/plug on the side - about the size of maybe a quarter.
When operating I noticed water was spraying around the grommit - never saw that before - in the bucket I noticed some brownish discoloration in the water foam. When I then went to change the lower unit oil - guess what - choco milk was flowing out...damn..
The motor had been last winterized about 8-10 years ago and was stored indoors. I took the motor to the local Tohatsu dealer to be prepped from it's long sleep of 8-10 years - they changes the impeller and fuel line - they said it started and ran fine. They also told me the water spray from around the grommet was normal...i have my doubts.
EDIT: The motor starts fairly easily, it idles - but if I bring down the throttle to bear min it sounds like it might stall - but it doesn't. Sounds fine once I bring up the RPM's.
So my question is this normal?
If it is normal, my assumption is that either the water pump seal or gasket is bad, or O-ring seal around the propeller shaft housing, or maybe even one of the screws for draining/filling the lower unit has a bad rubber washer. The screw washers seemed OK, but when I refilled with fresh oil, I noticed that some lower unit oil was seeping - might just be the fact that I didn't tighten it enough perhaps...
SECOND question - this engine seems to rev extremely high when I give it some throttle in Neutral - a bit scary - i can't open the throttle completely as I feel like the powerhead is going to explode....is this normal for a 2 stroke?
Thanks!
Thanks!
