I have oil running out of my lower unit. I have removed the outdrive and split the unit from the top.
After pressure testing with water pump removed, air and a little residual oil was coming up the vertical drive shaft.
Can I undo the carrier assembly and simply replace the seals or does the whole assembly need overhauling?
Thanks for any help.
