EST = electronic spark timing!
The distributor triggering unit runs 1:2 with the crankshaft, and with no mechanical advancing mechanism.
All progressive advance is achieved via electronic circuitry.
BASE advance is set while in BASE mode! Once set, return to run mode.
Since we cannot create a spark event any sooner than it's initiated, the distributor housing is positioned so that it gives full advance to the engine.
The ignition module then delays the spark event, and provides the progressive advance electronically by varying the delay progressively as per rpm.
Throw your timing light on number one cylinder, and watch to see if it progressively advances past BASE while you increase engine speed.
