I dismantled the above carb' as I've done in the past to clean it and sprayed the various jets etc. with carb' cleaner. The force of the spray on this occasion dislodged a small spring(one inch long and eight on an inch wide)and a small brass tube( inch and a half long and three sixteenth of an inch wide). I found them on the bench and did not see where they came from but suspect that it is the spring that goes under the power piston. No. 24 on my Instruction Sheet and that the tube which I cannot see on the Inst. Sheet slides down inside it and sits in the hole at the bottom of the "well" that the spring goes into. If that is the case is the tube just a push fit in the hole or what? I would be grateful for confirmation or otherwise.
