That switch goes to the older key switch panel, that is a vertical bracket about 6"x 2" and has bullet connectors on each wire. There generally is a toggle switch for choke on this panel. I do not think it is the panel you have for a 2005, since newer panels were out at that time.
It is also used in the older side mount control boxes, where the choke is to push the fast idle lever all the way up.
I guess I should have asked before......do you have a key switch panel on the dash or a side mount box? If you have a side mount box, is your old key switch a push to choke?....some of the newer ones are.
If you can take a picture of the key switch assembly and a picture of the connectors on the back of it, then I will know for sure which one it is.
You would think it would be simpler....
Mike
