Results 1 to 3 of 3
  1. #1
    Default Age old winterizing questions for VRO 40hp
    I know this is basic stuff, but haven't been able to find old thread covering winterization of motor with VRO system (mine happens to be 1992 40 hp). My OEM manual says to prepare shop mixture of 5 gal fuel, two quarts omc storage fogging oil, one point johnson outboard lubricant, one pint 2+4 fuel conditioner, and run that mixture through. Also says not to disconnect fuel line and run it dry as it will cause excessive oil consumption and may result in hard starting.
    Regarding the omc procedure in my service manual..... I've never seen fogging oil in quart containers, only in spray cans Also, don't have a spare tank for shop mixture. Suggestions on suitable alternate procedure to the OEM service manual?
  2. #2
    Join Date
    Apr 2010
    Posts
    3,893
    Default Re: Age old winterizing questions for VRO 40hp
    If you're not going to use the mix, put Stabil in the fuel tank and run it long enough to get through the system. And then fog the motor out with fogging oil when running it. This coats the whole inside of the motor with oil.
  3. #3
    Sounds good. Thanks.
Similar Threads
  1. Winterizing Merc MCM 898 questions
    By wish2fish in forum Mercruiser Sterndrive Forum
    Last Post: 11-10-2009, 07:54 AM
  2. Winterizing a b61 40hp
    By smokinone in forum Johnson Evinrude Outboard Archive
    Last Post: 10-06-2006, 07:30 PM
  3. Winterizing Questions
    By BRRRR_In_NJ in forum Archive 2003-2009
    Last Post: 11-06-2003, 04:22 PM
  4. Outboard winterizing questions
    By MIKEPAUL in forum Outboard motors archive 2000-2004
    Last Post: 01-06-2002, 01:00 AM
  5. Joe two questions on 40hp Johnson b88
    By PatrickC in forum Outboard motors archive 2000-2004
    Last Post: 06-11-2001, 11:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
