evenrude 1964 outboard engine
jcase
I'm having trouble trying to start my outboard idk what it needs to start it I think the carburetor on it messed up Wouk like some help
I've been to that site a ton if you look at it I'm missing like the inline mixture linkage and idk if that will help and should that little linkage on the carb help
The question is ---Do you have spark ?---------Spark must jump a 1/4 gap with a snap you can hear.---------Post results of that test !!!
Sorry , but you need to take the time to learn about doing a proper check of your ignition system !------It was designed and built to be able to jump a gap of 1/4" or more.----That is a true test of your ignition system.
I put the carb and choke cleaner for the carb so can it mess the carb up some and I'll try all that the fuel not that okd we put new mix in it and when I start it just dies also so Iput fuel mix in a spray and when I hit choke stuff just doesn't ooze out the carb
