Just purchased the factory water pump rebuild kit. Began disassembling the lower unit per instructions, but could not get the lower unit to fully drop. It felt like it was hanging up on something. Yes, I did disconnect the shift rod behind the water intake. It drops about six inches and won't drop any further. I thought maybe I should remove the upper connector, but the directions imply that that you don't do that until the after the gear case has been removed. I did try removing it, but it wouldn't budge. Any suggestions there? I'm pretty handy, but new to this outboard.
