Having a issues with my engine overcharging.
It starts off charging at 14.5v from cold and after running around for about 15 min @ 3500rmp and higher it starts jumping to 17,18 19+ v. It backs down if I reduce throttle to under 1000 rpm. I checked all the connections and even replaced the battery (it has and always has had ss nuts w lock washers). It is still doing the same thing. I verified it is not the gauge by connecting a volt meter right to the battery and got the same voltage reading as the guage. I check the voltage regulator connections and all looks good. I am assuming the voltage regulator is bad so I ordered a new one. But if that does not fix it , could the stator be the problem? I am quite baffled as to why a new parts like these would have gonna bad. But if anyone can think of anything else I should look at please advise. Thanks.
Just some history: In the spring I replaced my entire electrical systems with brand new CDI parts after having some igntion issues. NEW: power pack, optical sensor, wires, plugs, stator and regulator/rectifier.
Engine has been running great and even think it is using less fuel with the new ignition parts.
