kenpimentel
We have a 4-stroke Mercury 15HP 2008 outboard. When it runs properly, it will idle fine at low revs. It works just like we want it to. Right now, it is the engine from hell. Here are the symptoms:
- starting with cold engine:
- ambient temp: 60F
- start with choke out on 1st or second try
- exhaust is smoky white - assume it is unburned fuel
- I play with the choke, the cloud is less, but, engine won't stay running unless it is fully out
- With the choke fully out, put it in gear and get underway, engine is running poorly/uderpowered, so I push choke in a little
- Engine speeds up to expected power output, this lasts for about 2 minutes, then if I don't do anything, the engine will slow and die, putting the choke back in, gets it to run again, but poorly
- If I throttle up, everything seems to run as expected with choke in, no dying
- After 5-10m of running, the engine will barely idle with choke in. It runs very rough and will eventually die. Choke out will generally keep it from dying, but it runs rough
- I notice signs of fuel/oil? in the exhaust water, I don't remember ever seeing this before. This seems new. I think 4-strokes are not supposed to do this?
What I've done:
- I mounted a spin fuel filter on transom of dinghy and the fuel goes through that before going to outboard
- I only use non Ethanol fuel (it was a nightmare when I didn't)
- I replaced my fuel lines last year (because of the Ethanol destroying them)
- Thinking I over-filled the oil in the crankcase, so I removed oil until it is barely just 1/2 on dipstick, hasn't seemed to make a difference
- Replaced the spark plugs
- Removed the carburator and cleaned with carb cleaner - didn't see any junk in bowl
- Replaced the bowl gasket
- Checked the jets that I could check, they all seemed to be working
What I haven't done:
- The fuel is about 9 months old, I'm assuming it is OK, but I haven't tried with fresh fuel
What it means is that we can barely use our dinghy. At odd times, it stalls - generally when you don't want it to. My wife ain't happy about the situation - she's put me on notice.
Any help would be appreciated.
thanks,
ken
- ambient temp: 60F
What I've done:
thanks,
ken
