When i look at the pictures at the internet, then all the other impellers are looking bigger, can someone confirm that the dimensions are the same with a diffrent impeller and which one should i order?
In double checking and viewing very closelt your picture of the water pump kit, which includes the impeller which was what I wanted to examine up close.... I see that the impeller and the kit in general is for the 1979 35hp driveshaft which would have the flat spot cut into the driveshaft to accept the plastic shovel like impeller key.
This is going to create a problem as that impeller is not designed to operate or be driven with that small metal round pin. If you could locate the proper short driveshaft at a reasonable price
(Part #323261) , that would be the ideal way to go (but expensive). Should you think you've located one, the part number would be imprinted directly on the driveshaft somewhere... look for it closely.
Note that you cannot use the 1976 impeller as it's diameter is too large and it height is not high enough.
Ask your dealership to let you view (impeller in hand) the impeller part numer
388702. What would be the cheapest way out of the predicament you're in would be to have a impeller of the proper outside measurements BUT to simply have a rectangular slot cut into the inner portion for the pin... OR... instead of a rectangular slot, to simply have a half round slot cut there.
As a last resort.... you would need a new impeller of the same type in your present impeller housing, the
388702 impeller, BUT do design a pin in your driveshaft, cut to a proper length on your workbench as stated in my previous reply.
Let us know how things work out for you.
