Hi all! I recently baught a 1988 Bass tracker and it came with a 1986-1988 model year Minn Kota 24v all terrain 48 lb. I noticed that you can move the armature in and out a litte bit while it is put together alomost like it has a spring. Should it be doing this? I took it apart and everything looks ok and the bearings are all spinning free (brushes are a little worn but not terrible)
Also should the paper brush retainer go on the front side of the brushes (toward the prop) or the back?
Thanks for the help!!
