There should be a gasket at the base of the cap. it seals the cap to the base.
There is also a brass 90 degree tube sticking out of the cap to allow airflow.
is water bieng dripped on or spinning off the drive shaft all over the distributor?
Sorry guys. THought the two issues were unrelated and did two separate posts. See my other post "1979 GM V8 350 Timing Marks Must be Off"
Not an issue. These are two topics, so two threads is not uncommon.
for some of the other RELATED problems I've been experiencing. The cap itself is not vented but there are some screened vents on the neck thing below the distributor base.
Very common.
So you guys think I should replace the spring/weight advancer things in the distributor and that may make my motor run OK at 8 BTDC?
IMO..... DO NOT replace the flyweight return springs without the aid of a Distributor Machine and a Tech who knows how to operate it.
Gasoline Marine Engine ignition advance is far too critical to mess with when/if we are not well trained nor experienced.
If you have this done, the Tech will require your OEM ignition advance curve for your engine.
NOT AUTOMOTIVE specs!
Also, keep in mind that BASE advance is BASE advance ONLY..... and all day long.
We fire up on BASE, and we idle on BASE.
The important part of ignition advance is the Progressive and Total Advance and at the RPM as per OEM specs.
BASE advance gone bad may not damage a Marine engine, per 'se .... but the wrong or excessive Progressive and/or TA will damage a Marine engine.
Would it make sense to try to upgrade my mechanical distributor to a Thunderbolt. It sounds really cool!
That is entirely up to you.
The TB is EST... electronic spark timing. This means that ALL of progressive advance is turned over to electronics and the algorithm of the electronic module.
For me... NO! I'll stay with the mechanical for this particular engine. Your call.
Would it be more resistant to water corrosion?
First see where the water is entering. Is it via the engine hatch cover, or ____?
